Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: 250R caliper
  1. #1
    TRX310R is offline Newbie
    Join Date
    Apr 2009
    Location
    Lafayette, LA
    Posts
    22
    Default 250R caliper
    Hey all, i've been reading these forums for a while and only been polishing for a few weeks now. Just thought I'd post a few pictures of my latetst work and wanted to ask a few questions about the process.
    Started with this
    Now it looks like this...
  2. #2
    Join Date
    Apr 2009
    Location
    Lafayette, LA
    Posts
    22
    Default Re: 250R caliper
    I went to 600 on the top of the part and then to black/spiral, cleaned, brown/spiral, cleaned, then green/spiral...I can't seem to get the part free of waves after sanding smooth...any ideas?
    It looks like orange peel...what causes that?
  3. #3
    Tng21 is offline Amateur Metal Finisher
    Join Date
    Dec 2006
    Location
    Dereham, norfolk, UK
    Posts
    106
    what did you use to sand it with? paper, greaseless, machines?
    uneven surfaces sandng with greaseless on a mop can be one cause
  4. #4
    mpierich is offline Metal Finishing Guru
    Join Date
    Aug 2004
    Posts
    957
    I'm guessing greaseless. You need to use white compound with that to prevent the orangepeel.
  5. #5
    nfs2000 is offline Newbie
    Join Date
    Apr 2009
    Posts
    19
    Check out the bottom right hand corner of the pic below, yours doesnt look a million miles away from the same as my first (and current) workpiece.
    In the post i put up about it i was pointed towards obtaining a palm sander to get an even surface and also go to a higher grit level to get it more flat. That would be my guess based on current experience (which is little so dont quote me!)
    Just trying to share what little knowledge i have, hope the experts on here dont mind
    To answer the question properly i think we need to know how you sanded down the items and to what grit level before polishing.
  6. #6
    smooth72's Avatar
    smooth72 is offline Newbie
    Join Date
    Apr 2006
    Posts
    31
    Looks good, I did the same to my 310. Sand allot more before you go to the polish. Need to get it flat with sanding or grinding before going finer, I usally go down to at least 1000 grit. The polishing part is only about 10-20% of the process. Where do you ride? I usually go to Little Sahara in Oklahoma.
  7. #7
    Join Date
    Apr 2009
    Location
    Lafayette, LA
    Posts
    22
    I sanded the surface with some surface prep disks from harbor freight, I can't seem to find the item online but I used a die grinder with 150 and 240 grit disks and it took all of the casting marks out easily. You can see on the caliper bracket that it is really shiny...and all I did was sand with those two disks and then start with emery/spiral; tripoli/spiral; green/loose cotton
    On the caliper itself, I also used the two disks, then wetsanded to 600 then used emery/spiral; tripoli/spiral; and green/loose cotton...can't seem to get those marks to go away...
    We only ride here in louisiana at a small dune recreation area...heres a pic of my 310
    Lookin to upgrade to a 370!
  8. #8
    Join Date
    Apr 2009
    Location
    Lafayette, LA
    Posts
    22
    Found the item on hf.com...- Harbor Freight Tools - Quality Tools at the Lowest Prices They are not hard dicks, more like a super stiff brillo pad haha, so they conform to whatever shape you are sanding and will not gouge the surface with stiff edges like a grinding stone.
    The grey disk is 240 grit equivalent, but it seems to sand much finer than that...more like 400 b/c when I wetsand with 400 they have much more pronounced scratches then with the prep disk alone. I think I'll try to wet sand to 600 again and then go straight to the spiral/tripoli combo.
    Smooth your bike looks amazing...I think I have that same picture of it saved on my harddrive from a long time ago when I first started riding and reading forums lol!
  9. #9
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    jebus, those are some sick quads!
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
  10. #10
    smooth72's Avatar
    Join Date
    Apr 2006
    Posts
    31
    Your curve areas look good. If you have a da sander use it on the flat areas. I use the da with different sandpaper, lubricated with wd40. Make sure the sandpaper doesn't get any debris or build up or it will leave little swirls. Harbor freight sales little 3" polisher and sanders for around $30 to $40 dollars that work great. 3M makes a full line of 3" Velcro bake sandpaper. Now take on the cylinder.
Thread Information
Users Browsing this Thread
  1. Brake caliper pricing??
    By goincrzy in forum Powder Coating Questions
    Last Post: 11-05-2009, 11:03 PM
  2. Two Coat V2.0 GSXR Caliper
    By FiReBReTHa in forum Powder Coating Questions
    Last Post: 06-19-2007, 04:37 PM
  3. Brake Caliper ?
    By evill in forum Powder Coating Questions
    Last Post: 02-12-2006, 07:56 AM
  4. Brake Caliper Seals???
    By viper56 in forum Powder Coating Questions
    Last Post: 10-23-2004, 03:34 PM
  5. newbee/caliper plating
    By elocke in forum Electroplating Questions
    Last Post: 03-03-2002, 07:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
