You are very much welcome, Thank you for answering all the questions you answer on here.
The link below is the exact kit I bought. Any aluminum flux and aluminum solder should work. I use a soldering iron, a lot more precise than a torch. I also try to clean out the pit with a dental pic.
Before buying the kit I used regular solder, most of the times regular solder will not stick to aluminum, as soon as you clean the aluminum oxide layer off it grows a new one if exposed to oxygen. What I did was to put a drop of oil right on the pit, cleaned up the aluminum which removed the aluminum oxide. Put the tip of the soldering iron right into the drop of oil, it smoked a little but it did work.
UNTIL I tried to plate it, no matter what I did it seemed oil leeched out of the repair and contaminated the plating.
Harris Al-Solder 500 Aluminum Solder Kit
