I'm not as good as some of the guys on here but when I do steel the process I use is I get it to 600 grit. Now whatever you may use to get there is up to you. I use DA with scotch brite pads to gray, than wet sand 600. Making sure that when I sand I go in the same direction. Cross hatching lines, for me, tend to show up in the end a bit. Once at 600, I buff with black using spiral sewn wheel. followed with white using a loose cotton wheel. II used this exact process on my gas tank, rotors, etc. and it seems to work pretty well but on some pieces if I still see some lines I'll go over again from the buffing stage with black using the sisal wheel, then black with spiral, and white loose. Hope this helps ya out, and good luck.
LinkBack URL
About LinkBacks
