Results 1 to 7 of 7
Thread: Coloring brass
  1. #1
    DA45acp is offline Platinum Member
    Join Date
    Aug 2009
    Location
    Central Texas
    Posts
    3
    Default Coloring brass
    Ok, here is a question I can't seem to find an answer for. Is there a way to color or dye brass with out plating?. I have brass pieces that I want a bright color (green, red etc) not just nickel. Any thoughts?
  2. #2
    CarWiz's Avatar
    CarWiz is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    Default Re: Coloring brass
    Don't know exactly what you're after but chemical choices are slim. Maybe this might help.
    Caswell Inc. - Dupli-Color METALCAST ANODIZED COLOR
  3. #3
    woodjames's Avatar
    woodjames is offline Metal Finishing Guru
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    629
    About the only thing you can do with brass is add patina (antique it) it'll be a dull color, and you'll be very limited as to the range of colors that can be achieved. I think the suggestion of the metalcast paint would be your best bet, that or a candy powder.
    Quote Originally Posted by DA45acp View Post
    James Bateman
  4. #4
    Join Date
    Aug 2009
    Location
    Central Texas
    Posts
    3
    Question Re: Coloring brass
    I guess maybe a little more information might help. Might get a few more ideas anyway.
    What I have is brass shell casings. But then every one has brass shell casings which is the problem. I reuse these for reloading but then so does everyone else I know. I have tried machinist dye but it leaves a transfer in the barrel and after a while causes some fouling of the chamber. Also cases do not clean very well afterwards. Could use nickel but then so does some of the others... I just need to mark the cases permanently to identify mine and make them easier to find.
  5. #5
    CarWiz's Avatar
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    Yeah, paint won't do for that. These are old chemical names but most can easily be "translated" to current compounds. Some may be hard to get, like the chloride of arsenic but there's more colors here than I ever thought about.
    Brass Coloring
    Miscellaneous Coloring of Brass
  6. #6
    Join Date
    Aug 2009
    Location
    Central Texas
    Posts
    3
    Hey CarWiz thanks for the information. This is what I was really looking for. May have to give some of this a try.
  7. #7
    woodjames's Avatar
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    629
    Second that. I've seen red, black and Statue of Liberty colors, figured it was limited to that. Ohh, and can't forget the pink handprint from grabbing the outdoor brass knob with nitric acid on my gloves. Good link.
    James Bateman
Thread Information
Users Browsing this Thread
  1. Heat coloring steel. How to keep color?
    By s2k29k in forum Other Metal Finishing Questions
    Last Post: 07-10-2009, 01:46 PM
  2. Coloring by Lacquering Over Plating
    By Sakura in forum Other Metal Finishing Questions
    Last Post: 08-14-2006, 11:09 PM
  3. Silver Coloring question
    By alchemist in forum Other Metal Finishing Questions
    Last Post: 12-22-2005, 05:04 PM
  4. Inconsistent Coloring
    By PrecisionPB in forum Anodizing Questions
    Last Post: 04-03-2005, 05:07 PM
  5. Coloring/finishing Magnesium Bronze
    By homydog in forum Other Metal Finishing Questions
    Last Post: 04-03-2005, 01:03 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
