| Other Metal Finishing Questions Discussion board for any metal finishing questions not covered in the topics above. |
I have silk screened some brushed aluminum with uv ink, the aluminum I intend on bending into boxes, but I can already tell the ink will wear off over time without a clear coat. I need to clear coat these so the ink will be protected. I have thought of using polyurethane but that may not be suitable being these boxes are for guitar effects boxes and it could wear quickly. Does anyone have any recommendations for a good clear coat for this? Can I anodize them, will this remove the ink if I do? Should I use some type of automotive clear coat? I need some thing very durable. Thanks! |
anodising will remove the ink.
depending on the composition of the ink, car clear coat (in a rattle can) may make the ink run of blur. you can slilk screen anodise, that will work
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools. " - Douglas Adams The Darkside bdk Race Engineering
Thanks for the reply! I figured anodizing would remove the ink and i realize i have done this process backwards, but due to time restraints I have to figure something out very soon. I will try the car clear coat and see if that works. The ink is pretty durable to the touch and seems to hold up to the "fingernail" test but still needs further protection. I tried lightly spraying a tester with some poly and it didnt run. Ill try the car coat and wait for results. Thanks!
| Clear over blasted aluminum | JeffL | Powder Coating Questions | 3 | 08-15-2009 11:16 AM |
| Clear Coating Aluminum Rims | sage | Powder Coating Questions | 2 | 08-03-2006 10:33 PM |
| Bright Dip or alternitive, silk screening | Paintbalaguy | Anodizing Questions | 7 | 02-01-2006 01:16 AM |
| Clear coating????? | Dermagrfx | Powder Coating Questions | 1 | 08-24-2003 12:31 AM |
| Clear coating? | Derrick | Metal Polishing Questions | 9 | 06-16-2002 11:34 PM |
