Results 1 to 3 of 3
Thread: Firearm Refinishing
  1. #1
    dodger6768 is offline Platinum Member
    Join Date
    Sep 2009
    Posts
    1
    Default Firearm Refinishing
    What experience does anyone have in using the black oxide process to refinish firearms? How durable?
  2. #2
    mounty476 is offline Platinum Member
    Join Date
    May 2005
    Posts
    2
    Default Re: Firearm Refinishing
    I am a gunsmith and use the regular hot salts method. Yeah, I've got some scars and old burns, but the results are very nice. I have tried the black oxide blackening chemical once here and was not overly impressed with it. I just read the directions and might try something different.
  3. #3
    Brintiff is offline Amateur Metal Finisher
    Join Date
    Jul 2008
    Posts
    217
    Gunsmith here also, I would not use a cold black oxide to refinish a gun unless you want a flat black finish. The cold BO doesn't do well when applied to anything but a sand blasted surface, at least that is my experience. Unless you plan on refinishing a bunch of them it is not worth the investment in a hot black oxide setup. Hell, it's not worth it for most gunsmiths as the large bluing companies are so reasonable (checkmate is a big one).
Thread Information
Users Browsing this Thread
  1. engraved firearm electroless nickel
    By powderhombre in forum Electroplating Questions
    Last Post: 04-03-2008, 06:27 PM
  2. Refinishing my antique S&W .38-200
    By SGL1 in forum Electroplating Questions
    Last Post: 04-30-2007, 10:15 AM
  3. Firearm Electroplate Bluing
    By melloncollie in forum Electroplating Questions
    Last Post: 04-09-2006, 11:57 PM
  4. What do I need to plate an antique firearm?
    By duaneschliebe in forum Electroplating Questions
    Last Post: 10-08-2005, 12:13 PM
  5. Handgun refinishing
    By brokeback in forum Electroplating Questions
    Last Post: 12-08-2004, 07:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
