Results 1 to 3 of 3
Thread: blackening cad plated bolts
  1. #1
    pmackey is offline Platinum Member
    Join Date
    Sep 2009
    Posts
    1
    Default blackening cad plated bolts
    I am looking for suggestions on blacking factory cad plated bolts on a harley davidson motorcycle
  2. #2
    Rasper is offline Experienced Metal Finisher
    Join Date
    Aug 2006
    Location
    Huatulco, Mexico
    Posts
    360
    Default Re: blackening cad plated bolts
    I would probably throw them in a dish of muriatic acid for a few minutes to get rid of the cadmium and then paint them black.
    R
  3. #3
    XK120DHC is offline Experienced Metal Finisher
    Join Date
    Jul 2004
    Location
    Texas! Is there anyplace else?
    Posts
    282
    Or you can do it right.. Remove the Cad plating (probably Bright Zinc), replate with the Caswell Zinc/Copy Cad kit then "seal" them with Caswell's Black Chromate (NOT the "Blackener").
    You will get the corrosion protection with the zinc and the "look" of the Black Oxide without the rust issues.
    The upside to this is, you won't be adding "thickness" to the bolts/nuts like paint will and, it shouldn't chip like paint does.
    Back in '68, I built a 110 Cu In "Chopper" (a '39 Knucklehead), took great pains to paint all the nuts and bolts.. after assembly, there wasn't a nut or a bolt that wasn't all chipped up from the sockets and wrenches. Bummer!
    Charles
Thread Information
Users Browsing this Thread
  1. Blackening stainless steel
    By suegiordano in forum Other Metal Finishing Questions
    Last Post: 03-24-2010, 11:52 AM
  2. Blackening stainless
    By handirifle in forum Other Metal Finishing Questions
    Last Post: 03-23-2010, 11:09 AM
  3. blackening solution
    By hybred in forum Other Metal Finishing Questions
    Last Post: 08-09-2005, 07:41 AM
  4. blackening 303 stainless??
    By toku58 in forum Other Metal Finishing Questions
    Last Post: 01-27-2005, 02:45 PM
  5. Steel blackening
    By dburke26 in forum Electroplating Questions
    Last Post: 09-22-2003, 05:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
