Go Back   Caswell Inc. Metal Finishing Forums > Other Metal Finishing Questions
Connect with Facebook
Old 10-01-2009, 04:23 PM
vsodhani is on a distinguished road
Default Black Oxide Kit on Carbon Steel
Hi,
I am using Caswell Black Oxide on a piece of Carbon Steel that I am using to make a piece of jewelry from. The solution works perfectly and turns the Steel jet black.
The problem is that the piece after it has blackened gives off a putrid smell. There is nothing that I can do to get rid of the smell. I have tried to use Carbon Steel from two different vendors but both give off the same smell.
Any suggestions would be greatly appreciated.
Thanks,
Vikas
Old 10-01-2009, 07:50 PM
CarWiz's Avatar
Caswell Platinum Member
Talking Re: Black Oxide Kit on Carbon Steel
LOL... Yeah, it does have a rather pungent scent. The odor tends to wear off in time. It doesn't do well if exposed to handling or moisture without being coated though. I've never tried to make jewelry with it or use it for anything but nuts, bolts and brackets. It's acidic so neutralizing the surface may help. Have you tried to wash it in a soda bath and see if that helps? You'll need to dry it and oil it or treat it right away or it will rust.
3/4 hp vs 1 hp grinder/buffer, buffing carbon steel DNez2001 Metal Polishing Questions 4 01-08-2009 09:44 AM
Need help stripping nickel from carbon steel bigkidneys Electroplating Questions 3 10-14-2006 12:36 PM
Need Help w/ Black Oxide Kit salezdroid Other Metal Finishing Questions 3 11-18-2004 07:54 AM
black oxide bonesmachine Other Metal Finishing Questions 1 06-02-2003 01:03 PM
carbon steel sword DavidLen Metal Polishing Questions 2 08-23-2002 05:57 PM
