Results 1 to 2 of 2
Thread: copper finish for fire pit
  1. #1
    bbxrider is offline Platinum Member
    Join Date
    Nov 2009
    Posts
    2
    Default copper finish for fire pit
    any suggestions for a finish that can hold up to the heat in fire pit
    what i care about most is the 6" wide outermost ring, which of course gets super hot but it would be nice to hold up on the bottom as well but that is where its hottest of course. right now there is no grate on the bottom of the pit so the coals are right on the copper
    in lieu of that, how about an exterior grade finish, some kind of clear that
    just needs to be re-applied every so often?
    its amazing how fast it oxidizes after the vinegar/lemon juice/salt cleaner, which btw works better than any of the commercial cleaners i've tried.
    Attached Thumbnails Attached Thumbnails copper finish for fire pit-dsc00486.jpg
  2. #2
    CarWiz's Avatar
    CarWiz is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    Default Re: copper finish for fire pit
    There's not many choices that will take that kind of heat. I suspect that's why it's made of copper. You might try and have it ceramic coated but that might crack after the copper gets hot. Copper has a HUGE thermal expansion rate. I think the best solution is to clean it up and use a liner. A couple of layers of foil would work. When you're finished dump the ash, liner and all.
Thread Information
Users Browsing this Thread
  1. Fire arm plating
    By kmac in forum Other Metal Finishing Questions
    Last Post: 02-01-2008, 02:06 AM
  2. 25K plating over copper finish??
    By ringblingbelts in forum Electroplating Questions
    Last Post: 11-13-2007, 05:07 PM
  3. Copper-fired finish, How to
    By cottages in forum Electroplating Questions
    Last Post: 08-01-2006, 11:01 PM
  4. matt black finish on copper-plated steel
    By typewritermuseum in forum Other Metal Finishing Questions
    Last Post: 03-31-2003, 11:47 AM
  5. Plating for a Fire Place
    By Sunshine in forum Other Metal Finishing Questions
    Last Post: 11-21-2002, 11:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
