| Other Metal Finishing Questions Discussion board for any metal finishing questions not covered in the topics above. |
Quick Q...
Hello, I'm a new member with a Question on the Black Oxide Mix. I bought the 2.5 gal because I have a lot of washers that I'm making that I will coat. My Tanks are about 3/4 gal and I thought I could mix up the solution to the proper ratios to fill my tank. Once that was done I would take a ph reading of the solution as my base. I would take ongoing ph readings as I am plating, the solution would be acidic I believe. When I need to replenish the, indicated by a shift in the ph, I would add the concentrate until I reached the base ph. Does this seem reasonable or is there another way that would be more appropriate? Any help would be appreciated... CarveJunky |
| Need Help w/ Black Oxide Kit | salezdroid | Other Metal Finishing Questions | 3 | 11-18-2004 06:54 AM |
| black oxide - impressive | cray | Other Metal Finishing Questions | 0 | 11-03-2004 11:05 AM |
| Black Oxide vs. Parkerizing | ar15dcm | Other Metal Finishing Questions | 1 | 07-02-2004 01:59 PM |
| How Good is Black Oxide | bhysjulien | Other Metal Finishing Questions | 9 | 05-24-2004 09:12 PM |
| Bluing shotgun barrels with Black Oxide? | Beach004 | Electroplating Questions | 1 | 10-04-2003 09:18 AM |
