| Other Metal Finishing Questions Discussion board for any metal finishing questions not covered in the topics above. |
- if a vibratory tumbler could be used effectively to RE-finish used stainless steel golf clubs (i.e. to remove small dents and fine scratches) - if so, what the process might entail (e.g. number of steps, media and approximate tumble time for each) - whether or not you could tumble multiple heads (and if so, how many) at a time ... (I don't know anything about tumblers, but it seems like the heads might dump into each other, causing more dents than the tumbling process removes!) Any help is appreciated ... Thanks, Ken |
What media you use determines the results you get from any mass finishing system. Golf clubs can be worked and polished; however, one needs to know what media to use and this depends on how rough the surface is. Any indentation greater that .010 will probably require a rough ceramic shape composition media on SS in a wet deburring process. You may them have to go to a fine composition ceramic. Brightness can be restored with burnishing media, but smoothness is better with treated dry organic media.
AFK |
| Golf Clubs - How to remove nickel finish prior to refinishin | doctordave | Other Metal Finishing Questions | 3 | 06-03-2005 04:21 PM |
| Vibratory Tumbler Procedure | asallwey | Other Metal Finishing Questions | 0 | 09-27-2004 08:14 AM |
| Finishing metals with vibratory tumbler | rx7carl | Other Metal Finishing Questions | 6 | 07-23-2004 09:57 PM |
| Vibratory Tumbler Media | hondaman100 | Other Metal Finishing Questions | 6 | 08-27-2003 08:38 PM |
| Media to mirror polish Aluminum in vibratory tumbler | hrothgar | Metal Polishing Questions | 1 | 07-26-2003 12:32 PM |
