Old 02-17-2004, 11:59 PM
freematt
Default Cleaning Oxidized Aluminum With Sand Blasting Media?
The salt on the roads in winter here in the rust belt really messes up aluminum parts like transmission cases, timing covers, alternators, manifolds and valve covers I understand that some of the "sand blasting" abrasives used to remove rust from steel are not good for aluminum. Are there abrasives that can be used safely on aluminum? And what about durable coatings to finish aluminum after blasting, other than powder coating?
Matt
Old 02-18-2004, 08:08 AM
customandsound
Guest
Posts: n/a
you may be able to glass bead them or use a poly media . then repolish them and coat them with zoop ......
Old 02-23-2004, 02:22 AM
freematt
I read up on Zoop and I don't think it's the right stuff for auto parts that willl be subjected to salt spray. maybe a catalyzed clear coat, or silver or clear colored powder coating?
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
info on blast media Blademan Powder Coating Questions 7 05-18-2007 06:58 PM
cleaning anodized aluminum rancidnsx Anodizing Questions 0 01-26-2005 11:56 PM
Anyone with experience on tumblers or the media to use? krsimulis Metal Polishing Questions 0 06-02-2004 01:18 AM
Media to mirror polish Aluminum in vibratory tumbler hrothgar Metal Polishing Questions 1 07-26-2003 11:32 AM
