Old 07-19-2004, 01:23 PM
metalguy
Default Rust removal potions
Can anybody render an opinion on some of the commercially available rust removal concoctions that are now available, particularly Rusteco, Evaporust, and Safestrustremover.com. Thank you for sharing your experiences.
Old 07-27-2004, 10:51 PM
Moderator
bhhodges is on a distinguished road
i always use naval jelly
bill
Old 11-03-2004, 11:39 PM
Moderator
Naval jelly is great. I find however that 15 minutes in Pickle 2 does an awesome job. Just rinse and neutralize and rinse or the HCl doesn't know it's supposed to stop.
Kind regards,
Ken
Old 02-19-2005, 12:43 PM
vemoo
I give, what's "Pickle 2"?
Old 02-19-2005, 12:53 PM
Moderator
Pickle 2 is 1 part HCl and 2 parts distilled water. This terminology is out of the Caswell manual. The HCl is simply the grade commonly avaliable from Home Depot as Muriatic Acid. I believe it is a 31.45% mix as purchased.
Kind regards,
Ken
Old 02-20-2005, 10:46 AM
vemoo
Thanx for the explain. I've had good success with oxalic as a less aggressive acid which provides some brightening.
Old 02-20-2005, 11:10 AM
Moderator
Thanks for the tip. I'll give it a try.
Ken
  #8 (permalink)
Old 02-20-2005, 01:47 PM
sswee's Avatar
Moderator
Just a note, Oxalic acid is the main ingrediant in carburetor cleaners. I usually get it in 5gal cans.
  #9 (permalink)
Old 02-20-2005, 03:22 PM
Moderator
It's also found in wood bleach; can be bought by the pound.
Ken
  #10 (permalink)
Old 02-27-2005, 12:29 PM
Moderator
Permatex makes a nice naval jelly #81756 that can be used to remove rust in the presence of plating. The plating is relatively undisturbed and the rust is removed. I use this when a customer wants a part cleaned up but does not want to pay for replating. I buff with white compound afterwards to remove the slight tan staining that the formula leaves on the plated area of the part. The results are quite impressive...although obviously you still have an area left unplated.
I've also done this followed by replating. Since it's much gentler than hydrochloric acid, the rest of the plating stays intact and the amount of prep work is minimal. Again, the results are somewhat of a compromise vs. stripping and restoration, but sometimes this is all that is requested.
Ken
Copy Chrome rust showing through LeeParsons Electroplating Questions 3 08-19-2005 01:14 PM
Chrome wheels have slight rust and little bubbles can I buff fizlfry Metal Polishing Questions 7 04-28-2005 01:39 PM
Do ALL freshly polished metals rust? kwood69 Metal Polishing Questions 4 10-26-2004 11:25 PM
dull finish on old bolts with rust pits fordmerc Electroplating Questions 1 02-15-2004 04:22 AM
Steel motorcycle frame rust question..... noob-polisher Metal Polishing Questions 3 11-08-2002 02:14 PM
