| Other Metal Finishing Questions Discussion board for any metal finishing questions not covered in the topics above. |
If I am Chrome Plating or Anodizing aluminum, what can I put over parts to keep it from being plated or anodized. Example, if I don't want to change the finish over a screw hole or over a stamped stainless steel ring, what can I use to keep it from being received as well.
Would silicon work? any ideas are appreciated. Pat |
You can use Clear Lacquer to protect areas of parts you do not want to plate.
It can be left on after plating or removed with Lacquer Thinner. If you're going to plate with Copper...leave the 'resist' on it since you'll need to spray a coating of Clear Lacuer on the finished plating anyway to prevent it from oxydizing.
- etcc "1,200 Year Old Highlander Immortal" |
| Stripping chrome plating from aluminum | bbqboyee | Anodizing Questions | 4 | 04-22-2006 01:22 AM |
| Hello. Need plating services, will pay a fair rate. | vilsk | Electroplating Questions | 3 | 08-13-2005 07:32 PM |
| There seems to be alot of leg work in plating PLEEASE HELP | wonbadmfer | Electroplating Questions | 24 | 12-07-2004 08:19 PM |
| CopyCad & Zinc failure - electrolyte problems? | seanc | Electroplating Questions | 4 | 11-08-2004 09:16 AM |
| Anodizing Power Supply Q's | jnbsystems | Anodizing Questions | 7 | 10-02-2003 10:33 PM |
