| Other Metal Finishing Questions Discussion board for any metal finishing questions not covered in the topics above. |
i am not sure about this one .. you can contact caswell direct there # is on there webpage. www.caswellplating.com
Traciej68, sure, you can plate cast iron.
Degrease and clean the part. Use the gelled type paint stripper to remove any paint. Wash off and dry. Bead blast the part to get all the rust off the part. Buff with a Nylox (or similar) abrasive wheel (will brighten up the final plating appearence). One more scrub down with Caswell degreaser. Rinse well (tap water ok for this step)! Dip for (30) seconds in nickel pickel. 30 second distilled water rinse. Go "Hot" (electrically connected) into the bath. Lots of large air bubble action in your tank. Anode at least 3" away from part. Increase the current by a 2X factor for the first (3) minutes (insures it starts to plate rather then rust in the solution). Plate for at least 1 1/2 hours (.0015-.002" plate thickness). The picture shown is the results you should get (If I uploaded it ok). George W. |
| Cast Iron ???? | fking962 | Electroplating Questions | 2 | 09-04-2005 02:52 AM |
| Anybody ever polished a cast iron engine block? | thesound | Metal Polishing Questions | 5 | 02-10-2005 11:31 AM |
| Bare Cast Iron Look.... | Wkillgs | Powder Coating Questions | 6 | 11-13-2004 08:45 PM |
| Prepping cast iron. | Stytooner | Powder Coating Questions | 3 | 08-04-2004 10:30 AM |
| Cast iron prep | ewmorritt | Metal Polishing Questions | 1 | 05-28-2003 01:31 AM |
