| Other Metal Finishing Questions Discussion board for any metal finishing questions not covered in the topics above. |
You don't stop riding because you get old, you get old because you stop riding |
shawn now that you fired it up that stuff will not come off .. the hotter it get's the harder it get's ...
What the tech line got is ceramic that melts under heat to form a barrier.. The spray on high temp coatings you get at the auto parts store dose not have a bonding agent .. so in turn it flakes and burns off They look good |
Well I think it's safe to say that after several hundred miles this coating is worth so much more than what I paid. Looks good, doesn't burn off and total investment after buying a spray gun and compressor is less than what a powder coater would have charged to coat the exhaust. Only used 2 oz (rough guess) to spray a 4-1 motorcycle exhaust.
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
Hi im new around here and im looking forward to ceramic coat my header but the prices are outragious . Techline is only 20$ and seams really good by looking at the tread . The only question i have is surface preperation . Do we need to sandblast the header ? Or just a good cleaning using paint thinner would work ?
will this gun do the job ? http://cgi.ebay.com/HVLP-PAINT-GUN-S...QQcmdZViewItem Would a nomal gavity paint gun do the job too ? Instead of buying 2 different gun . http://cgi.ebay.com/ebaymotors/10-Pi...18846899QQrdZ1 Last edited by Nos; 08-21-2006 at 01:28 AM. |
either gun will do the job as long as you have a 1.0mm or smaller tip. as for prep if you dont get the headers blasted it probably wont hold up. the surface needs to be cleaned very well as well as be roughened up so the ceramic has some place to bite into the tubing. also when blasting be sure not to use glass beads. the manufacture says specifically not to.
As for the beads your saying to use aluminum oxide ? For the cleaning part what product can i use to do a good cleaning ? When you says the part needs to be roughened up , what do you mean by that ?
thanks alot ! Last edited by Nos; 08-21-2006 at 01:11 PM. |
| Tech Line Coating, will this gun work? | Noob2PC | Powder Coating Questions | 11 | 10-17-2004 05:37 PM |
| Powder coating over nickel and creating a paint line | pelletman | Powder Coating Questions | 1 | 07-29-2004 10:13 PM |
| Tech Line Coating? | WAORacing | Powder Coating Questions | 0 | 04-20-2004 11:28 PM |
