| Other Metal Finishing Questions Discussion board for any metal finishing questions not covered in the topics above. |
I'd to coat new brake rotors for my car, to prevent the corrosion that goes along with exposed metal and heat. I have tried hi-temp spray paint in the past and I'm never happy with the results. I'd prefer a black color, but the least expensive and most effective, as well the least interfence with heat transfer/cooling of the rotors, is a higher priority than the color. At first glance, it appears Caswell's Black Oxide Kit is the solution. But there is no reference to temp resistance. Will the Black Oxide Kit coating stand up to high heat, such as a brake rotor experience (this is for spirited street driving, so it gets hot, several hundred degrees, but NOT glowing red like NASCAR)? As well, the extreme corrosive environment? If not, what would be the best coating? What about the coating the swept area of the rotor?? Will it interfere with the brake pads?? How deep does the coating and sealer penetrate the metal, will it wear down to bare metal under the swept area of the brake Pad quickly? Should I Mask off the swept area of the rotor, to prevent it from being coated?? If so, can I use normal masking tape or do I need something special? |
Black Oxiding certainly won't withstand the heat, wet and overall abuse.
Almost any coating would do better. Look at VHT & Krylon Caliper paints.
| Removal of unknown coating on aluminum | rclint | Metal Polishing Questions | 6 | 08-25-2005 01:04 AM |
| plating M/C brake rotors | snortn850 | Electroplating Questions | 2 | 02-05-2005 12:53 AM |
| First successful powder coating project! | kcrails | Powder Coating Questions | 5 | 06-28-2004 06:07 AM |
| Non-paint powder coating | dshepherd | Powder Coating Questions | 6 | 01-26-2004 12:49 PM |
| Does a coating exist that can be bent slightly? | Augest | Powder Coating Questions | 1 | 09-22-2003 02:34 PM |
