Old 06-09-2005, 08:55 AM
vaudouu
Default 3M Liquid Glaze Compound with Flannel Wheels?
Hi,
I am trying my new polishing arbor. I am planning to use a flannel buffing wheel in order to bring my drum shells to a high luster. The clear coated was sanded up to 2000 grit. Can I use 3M liquid compound to achieve it? Or do I actually need to use dry compound?
Thanks,
Eric
Old 06-09-2005, 11:33 AM
sswee's Avatar
Moderator
The liquid glaze will work. It's what I use to use on auto paint work. It will probably be a little messy. Be careful not to burn the coating. SS
Old 06-09-2005, 01:18 PM
vaudouu
Default thanks
My buffing whells will run at 860rpm. Do you spread the glaze on the surface or do you "soak" the flannel wheel with the glaze?
Thanks a lot.
Eric
Old 06-09-2005, 03:36 PM
sswee's Avatar
Moderator
I use to spread it on the area being buffed.
Old 06-11-2005, 12:53 AM
customandsound
Guest
Posts: n/a
when i buff out my painted and powder coated parts i use carnuba wax it makes them shine.
problems polishing aluminium alloy with white compound rotorman Metal Polishing Questions 6 08-02-2004 12:57 PM
Cant get compound onto the wheels 1105 Metal Polishing Questions 3 04-28-2004 09:05 AM
pushing compound about on aluminium whistule Metal Polishing Questions 13 12-26-2003 11:32 AM
A ? regarding polishing aluminum wheels... geotexZ71 Metal Polishing Questions 4 04-25-2003 08:12 AM
