| Other Metal Finishing Questions Discussion board for any metal finishing questions not covered in the topics above. |
This may have been covered already, but I couldn't find anything on it. Is there a finish that can be applied over existing chrome on a golf club (soft Japanese carbon steel) that will be durable in either a black chrome look or a black satin or oil can finish look.
If so, where can I get the product and what are the procedures to achieve a black chrome finish or a matte black, oil can finish. thanks in advance, Roger ![]() |
Sswee is correct - powder coating with Liquid Smoke would be your best option. You could strip the chrome off and Black Krome plate the nickel that is under the chrome, but it would need to be clear coated or the Black Krome will wear off very quickly.
Really i would strip it and rechrome it with black chrome the powder coating would work also . I chrome plate a lot of club heads here in the area. The real fact of the matter is that most golfers put dings in there
clubs regularly so its kind of an on going thing I have customers that come back 2 and 3 times a month
Jim Eaton Last edited by jimcarry; 12-04-2005 at 08:33 PM. |
Thanks for all the input. The clubs that I have are expensive custom clubs forged in Japan at the famous (at least to golf club aficionados) Miura forging house in Himeji City Japan. They are forged from mild steel to precise specs and are highly coveted clubs. The big manufactures like Titleist and TaylorMade send their prototype club designs to Miura to be forged for their PGA Tour players. The Tour players do not play with the Chinese mass produced clubs that are sold to the general public.
Anyway, I love these clubs except for the fact that they have a polished chrome finish. So I am just looking for a way to cut down on the glare and I have always liked the look of a gunmetal or black oxide finish. What if I just stripped the chrome and left the nickel? Would it still have the polished chrome look to it? Would it rust? I wouldn't mind a controlled rust. What is the best way to strip the chrome? |
To remove Chrome and Rust
first you will need a tank large enough to hold the part a piece of stainless steel size depends on the part you are de plating a power source battery charger will work there are different type of Acid Pickles they are explained in greater detail on pages 34 35 and 36 of the Caswells Plating Manual WARNING ! Never pour water into Acid always pour acid into water Pickle 1 used for mild etching before plating to make this solution 20 parts fresh water to 1 part muriatic Acid for etching soak part for 1 to 15 minn 1 hour will remove rust from most steel Pickle 2 also rust remover and de- plater to make 2 parts fresh water 1 part muriatic acid to remove Chrome hook you positive lead to you part and your negative lead to the stainless adjust your power to 1 amp per sq inch de-plating should be complete in approx 15 to 20 minn DO NOT use this method on Pot metals or aluminum !!!!
Jim Eaton |
| Golf Club Heads.. | hvac36 | Powder Coating Questions | 3 | 02-21-2005 11:18 PM |
| golf club heads. | skeleton | Electroplating Questions | 4 | 02-01-2004 12:22 AM |
| plating a golf club | matt36887 | Electroplating Questions | 4 | 11-20-2003 03:45 PM |
| Golf Club Chroming | slater | Electroplating Questions | 5 | 05-26-2003 11:07 AM |
| Golf club finishing | homydog | Other Metal Finishing Questions | 2 | 02-20-2003 05:37 AM |
