hmm thought I could just edit a post to add a picture. Here is the wiring photo (without protective case for clarity.)
Make sure that you have almost zero resistance between the ground and the tank. Scratch off a little paint on the outside of the tank where the ground wire touches the tank. Then measure the resistance between the pump's ground(the 120 volt plug) and the heater's ground (the 240 volt plug). If the element or pump go bad, you want to ground through the ground wire not your feet.
David
LinkBack URL
About LinkBacks
