Old 02-22-2006, 07:49 AM
gestalt is an unknown quantity at this point
Default Can you dip Ceramic Coating.
Just wondering if it is possible to dip ceramic coating in a tank instead of spraying it?
Old 02-22-2006, 09:42 AM
pickleboy's Avatar
Default Re: Can you dip Ceramic Coating.
yes you can dip it but it is not the preferred way to do it. think about a flat sheet when you dip and pull it out the excess will start to run off. the coating at the top will be thinner than that on the bottom. if you want to do it so as to get the inside of header tubes, then the answer is yes but it will take a good amount to be able to submerse them. hope this helps bro.
Old 02-22-2006, 06:26 PM
machone's Avatar
machone will become famous soon enough
To get the inside, cap the end, pour coating in & turn the pipes to spread it, pour out excess, cure. try to use just enough, I think you will have adhesion problems if you reuse the excess. Tricky stuff!
mach
TSA Custom Metal Finishes
Live fast, Die sideways
Ceramic coating dbug10 Oven Building Forum 4 03-06-2006 12:44 AM
looking... yellow ceramic coating... MikeWalker Services Offered/Wanted 2 09-27-2005 09:34 AM
Ceramic coating for wear rclint Other Metal Finishing Questions 0 08-23-2005 10:23 AM
Ceramic Coating an Engine Block? thesound Powder Coating Questions 13 02-19-2005 07:37 PM
