Old 01-27-2003, 02:29 PM
Moggy
Default Electroforming Problems
I just purchased your Copper Plating kit, 16 Gallon, with a 25 amp rectifier.
I seem to be able to plate brass fine, but when trying to plate non metalic objects end up with a rough sand papery finish. The maunual says to plate at 1 volt for 30 min, then up to 1.5-2 volt. There is no mention of the correct amperage although at the beginning of the section on copper plating it says .05-.1 amp pre square inch. My rectifier is showing 3-4 amps @ 1 volt and I can not decrease it.
Any ideas?
Thanks
Old 01-27-2003, 07:12 PM
mcaswell's Avatar
Caswell Inc Founder
Sounds like too much power.
Please post a problem report in our PRS system and we'll sort it out for you.
Have A Web Site?
Dye problems with bead blasted finishes Easttex Anodizing Questions 17 12-14-2004 01:18 PM
Follow up to Copy Cad problems 69t120 Electroplating Questions 1 09-06-2004 09:31 AM
Problems using 12asf and 4.5asf! Chevalier Anodizing Questions 3 02-04-2004 08:55 PM
Does grease in the electrolyte cause problems? M_D Anodizing Questions 5 01-23-2004 03:11 PM
Consistency Problems NeoMoses Anodizing Questions 6 12-13-2003 03:01 PM
