Old 10-25-2006, 05:36 PM
boston_jake01 is on a distinguished road
Default Pin stripe adhesive removing
I was wondering if there is any quick way to remove adhesive from fenders?
I am sanding them for repaint and was trying to wet sand them off but it is taking forever.
Thanks
Old 10-25-2006, 10:19 PM
sswee's Avatar
Moderator
Default Re: Pin stripe adhesive removing
They have rubberized wheels just for that. They can be found at several places but the only one that comes to mind right now is the Snap-on dealer. They are 3" or 4" diameter, 1/4" to 1/2" wide, mount on an arbor and usually yellow in color.
SS
Old 10-26-2006, 07:30 AM
what is an arbor and how does this work?
I also noticed some of your work very nice, I really like the manifold, I waswondering when you did that did you have to polish it smooth so the finish will look smooth?
Old 10-26-2006, 10:22 PM
sswee's Avatar
Moderator
There are several different styles but most are similar to the one here
http://www.caswellplating.com/buffs/arbor.htm
The manifold started out to be polished for anodizing but the guy changed his mind and decided on PC. I took the Elderbrock name and model off with flat pads and worked the crannies with cartridge rolls. The runners were sanded to 400 grit and very little buffing done before PC. The look it has comes from the smooth surface and I slow ramped the temp to get the most flow out before it started to cure.
SS
Old 10-27-2006, 08:50 AM
well it looks great.
Old 01-20-2007, 08:41 AM
FGraphics
3M makes a product called Woodgrain and Stripe remover. this works great for removing all types of vinyl along with its adhesive even the vinyl that breaks off into little peices. Once this is sprayed on it, the vinyl will just peal off. Other wise, we often us a product called Rapid Remover to remove the glue residue.
Old 01-20-2007, 11:44 AM
jrow is on a distinguished road
Thanks
Have you tried Lacquer thinner, Acetone or MEK?
John
  #8 (permalink)
Old 02-08-2007, 08:39 PM
gasservettes is on a distinguished road
Oven Cleaner Works Great Or Nail Polish Remover
