Old 11-03-2006, 09:30 AM
base729 is on a distinguished road
Question Mill Enclosure - Coolant Problems
I am waiting for delivery of my desktop CNC mill. I have designed a sheetmetal enclosure for it to keep all the chips and coolant from going everywhere. I have a nice garage so far, so I want the enclosure to look good (i.e. I want to paint it), and I'm concerned about corrosion since the coolant is water-based. I can't seem to find a good coating to use for the inside of the enclosure. I will be wiping it down with chips and abrasive items, so I need something that will last.
Any ideas?
Old 11-04-2006, 10:12 AM
jrow is on a distinguished road
Default Re: Mill Enclosure - Coolant Problems
base729,
Have someone bend a galvanized pan for you and solder the corners. Or you can have a stainless steel pan bent and TIG the corners!
John
Old 11-04-2006, 06:38 PM
chromeitout's Avatar
chromeitout is an unknown quantity at this point
Powder coating would hold up pretty good under normal use. You wouldn't want to sand it but just wiping down with a cloth shouldn't hurt it that bad. I think our CNC's at work are powder coated. You could bend all of your panels, have them pc'ed, and use stainless pop rivets to assemble them.
Dye problems with bead blasted finishes Easttex Anodizing Questions 17 12-14-2004 01:18 PM
Follow up to Copy Cad problems 69t120 Electroplating Questions 1 09-06-2004 09:31 AM
Problems using 12asf and 4.5asf! Chevalier Anodizing Questions 3 02-04-2004 08:55 PM
Does grease in the electrolyte cause problems? M_D Anodizing Questions 5 01-23-2004 03:11 PM
Consistency Problems NeoMoses Anodizing Questions 6 12-13-2003 03:01 PM
