| Other Metal Finishing Questions Discussion board for any metal finishing questions not covered in the topics above. |
What sort of steel are they? What's your prep and parameters?
-- Lance Caswell Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm Please support the moderators on our site by leaving reputation for their helpful posts. Read more here. |
Hmm, well....black oxide doesn't work on stainless. You need our Stainless Steel Blackener.
Did you ever get the 370 to work? There is little or no information about the 370, not even a tutorial. I have tried just about everything including the countless one line instructions via email from tech support and the $320(4x$80ea) worth of barrels I've ruined really sucks(and I don't mean cosmetically either, they cannot be used because they are etched VERY badly). I even purchased some industrial grade muriatic acid(80%) as suggested and nothing seams to keep the parts from looking like they have leprosy(like your photo of the screw) or to keep from just wiping what little spots of black there is off with a rag? TIA |
Can you please provide the tech support ticket numbers for this problem. Stainless steel blackener shouldn't rust the parts like that. Are you sure they're stainless? What alloy?
Hi Guys,
I am having simmilar problems to yours. Did anyone manage to solve this issue. What type of surface prep are you using and are you etching in any acid and rinsing before the parts go into the blackening solution. Another question i have is are you using the blackening solution at full strength or diluted? Will this have any effect? From experiments i have conducted on four identical components i have only got one to come out well so i am lacking consistency. Process was as follows:- Degreasing Rinsing 2 min dip in HCl 50% solution Rinsing 2 min dip in Blackening solution Rinsing Drying Heat in oven 250 deg C for 15 mins Water quench Any suggestions are welcome Thanks. |
| Need production Black oxide and nickel on brass | shuey911 | Services Offered/Wanted | 3 | 01-24-2007 02:49 PM |
| Need Help w/ Black Oxide Kit | salezdroid | Other Metal Finishing Questions | 3 | 11-18-2004 06:54 AM |
| black oxide - impressive | cray | Other Metal Finishing Questions | 0 | 11-03-2004 11:05 AM |
| Black Oxide vs. Parkerizing | ar15dcm | Other Metal Finishing Questions | 1 | 07-02-2004 01:59 PM |
| How Good is Black Oxide | bhysjulien | Other Metal Finishing Questions | 9 | 05-24-2004 09:12 PM |
