Old 02-17-2007, 04:46 PM
PrestonHerrick is on a distinguished road
Default Duplicating look of bright dip
Did a search on this but found nothing or missed it. What would be the best process for duplicating the look of bright dip on auto trim (after it's been stripped) without using the usual nasty chemicals associated with it?
Old 02-18-2007, 10:13 PM
cprocess is an unknown quantity at this point
Default Re: Duplicating look of bright dip
Bright dipping typically refers to removing the metal oxides from the surface, as well as dissolving the "peaks" of the surface to match the "valleys", producing a smooth highly reflective finish. This can also be done by mechanically buffing and polishing the metal until you get the same result. You need to start with a fairly rough buffing wheel or sandpaper, then increase the grit number to polish grade. Need to wet sand if using sandpaper. If using buffing wheel, use appropriate buffing compounds (from buffing compound to polish compound).
Old 02-19-2007, 06:09 PM
Thanks. I've stripped and buffed parts before. Just wondering if there was a similar plating method to achieve the look and durability. I'm considering buffing and powdercoating with clear now.
Bright Dip? hurricaneracing Anodizing Questions 1 09-30-2006 09:15 PM
Cleaning Fine screen somnambulant Electroplating Questions 1 08-08-2006 01:24 PM
Bright Dip? rayginn_mfg Anodizing Questions 2 04-22-2006 12:27 AM
Bright Dip or alternitive, silk screening Paintbalaguy Anodizing Questions 7 02-01-2006 12:16 AM
