| Other Metal Finishing Questions Discussion board for any metal finishing questions not covered in the topics above. |
I'm using the setting Caswell Europe suggest (0.14A & 90F)
Anyway I tested three similar samples today - 3" lengths of steel tube that had a surface area of 5.65 sq in. Used a second heater to get the temperature up - was 35 centigrade (95F), and the parts were warmer than that from the cleaning dip. Plated them all for 20 minutes at the following settings: 0.56A, 0.68A, 0.79A That covers 0.1 to 0.14A per sq in. Results were all very similar, part plated but was covered in a grey layer that looks very similar to grey primer from a spray can (similar thickness too). It took at least 5 minutes for the acid dip to remove this layer. Part after plating: http://users.pandora.be/peter.morley...s/Plating1.jpg Close up of the grey finish: http://users.pandora.be/peter.morley...s/Plating2.jpg Part after 5 mins in acid bath - still some trace of the grey layer: http://users.pandora.be/peter.morley...s/Plating3.jpg Also tried one with brightener and no noticeable effect. It still seems to me that there is something contaminating the surface finish, no one else mentions having to do so much work to reach the plating. |
Peter:
However, I have visited Caswell UK web site, and it appears to have contradictory information: They claim it is the "new formula", but specify 30ºC & 25 mA/sq-in, which are the figures from the OLD formula. The kit is supplied with "Copy Cad/Zinc Crystals with Activator (New Formulation)". There is no "activator" used in the US kit, so it may be that the chemicals are significantly different. If that is the case, then my advise may be worthless. Contact Caswell technical support and sort it out. Quote:
If you do suspect contamination of the electrolyte, filter it and try again. But in any case, contact Caswell & get the numbers sorted out. Sean
Seans Zinc Plating page |
Thanks Peter |
What did Caswell suggest? Sean
Caswell UK was going to check with the US, but I didn't hear back from him.
I'll chase them up next week - I'm thinking that the easiest solution will be to get a new bottle of solution, as well as an extra zinc anode to allow for larger surfaces. |
| Copy Cad with heaters, Temp. up past?? | MrPontiac | Electroplating Questions | 6 | 12-16-2006 09:23 AM |
| copy cad power problems....I think?????? | lintmann | Electroplating Questions | 9 | 10-20-2006 11:39 AM |
| Copy Cad problems | only658 | Electroplating Questions | 2 | 02-18-2006 11:29 AM |
| Follow up to Copy Cad problems | 69t120 | Electroplating Questions | 1 | 09-06-2004 09:31 AM |
| Problems with Copy Cad | Matt Harwood | Electroplating Questions | 1 | 05-12-2003 09:29 PM |
