| Other Metal Finishing Questions Discussion board for any metal finishing questions not covered in the topics above. |
Someone had used a caustic solution of some kind, on our motorcycle engines.
The result is the anodizing was ruined and now the engine cases are corroded, I think. How does one get inside the deep crevices? Last edited by tmboracles; 07-06-2007 at 12:36 AM. |
yes caustic solutions will remove anodize ,it will also damage the aluminium , the extent of the damage depends on the strentgh of the solution and the time it was left on the part . you have diffrent ways of fixing it . you can polish the cases (yes they need either a protection or you will have to repolish them )
you can also glassbead them and have them powdercoated a solid color or polish them then powdercoat over the polishing with any candy top coat colors |
| MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! | NautiShine | Metal Polishing Questions | 61 | 05-15-2008 02:03 PM |
| Motorcycle master cylinder Sight glass? | cdaeme | Powder Coating Questions | 11 | 06-04-2006 08:55 PM |
| NAUTICAL METAL AND MOTORCYCLE POLISHING IN FLORIDA! | NautiShine | Services Offered/Wanted | 5 | 06-08-2004 07:21 AM |
| Any motorcycle guys out there? ... I've got questions.... | NYCmotor | Other Metal Finishing Questions | 3 | 03-24-2004 12:48 PM |
| Motorcycle Plating | czucker@randomhouse.com | Electroplating Questions | 3 | 01-06-2003 04:44 PM |
