Old 03-18-2003, 09:24 PM
trw trw is offline
trw
Default Aluminum Solder Paste
I purchased this product to fill a gouge in an anluminum mag wheel.
I can not get it to melt. I have tried a propane torch and a butane torch. It seems to start to melt and then does nothing. After it cools it just wipes off.
If I try it on an eighth inch thick aluminum bar it melts and beads to a ball. I thought it would flow.
Am I doing something wrong or just not enough heat from the butane (it is supposed to go the 3100').
Thanks
Terry
Old 03-19-2003, 11:50 AM
mcaswell's Avatar
Caswell Inc Founder
Try heating the part first in an oven. That will help the solder flow more smoothly.
Have A Web Site?
Old 03-25-2003, 08:55 AM
marsfrogie
Send a message via AIM to marsfrogie
You could try using Mapp gass instead of propane.
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Newbie, trying to find best way to finish aluminum-LONG POST chik Metal Polishing Questions 6 03-14-2005 08:11 PM
Stripping solder / gold plating pcb fingers clab Other Metal Finishing Questions 0 07-27-2004 04:32 PM
anodizing solder aluminum buckeyevs Anodizing Questions 3 02-27-2004 05:20 PM
HELP! White haze when degreasing polished aluminum! davidh90046 Metal Polishing Questions 2 10-15-2002 01:19 PM
