  #11 (permalink)
Old 09-11-2007, 01:39 AM
BerkelUSA's Avatar
BerkelUSA is an unknown quantity at this point
Send a message via AIM to BerkelUSA Send a message via MSN to BerkelUSA Send a message via Yahoo to BerkelUSA
Thumbs up Re: Vacuum Sand Blaster
promo.. a truck cab on a 3' stand looking in from the rear window makes a nice HUGE cabinet if you have an extra one kicking around??
Both doors become the loading areas.. you can hold an entire car-door or motorcycle frame in there easily.. just add some sort of hanging hooks to hold what your blasting or the item will be a pain to move around..
and it so big that there is no vacuum needed..
want example pics?
Rob
  #12 (permalink)
Old 09-11-2007, 02:12 AM
chromo
Default Re: Vacuum Sand Blaster
Great idea. A couple pics would be nice if you have some but I get the idea.
I don't have a truck cab handy I want to use for this right now, but I may be stripping a couple junk vans soon and was thinking about using the rear body section like this. Easy loading through swing open rear doors. I'll have to make the other end when I cut it though. I want the van frame from under it for a project.
Hey I'll probably get the PA Blaster plans and join up next week, I just got some nice plumbing tanks at an auction cheap and need to do something with them
I think they had something to do with water softeners, fiberglass tanks, should hold lots of media.
  #13 (permalink)
Old 10-18-2007, 09:21 PM
Caswell Platinum Member
JAP_NDN
I tried the Harbor Freight one. I was quite dissatisfied with it and ended up returning it. That's the beauty of HF. The blaster just didn't have the power to do much. I ended up going back to my $20 Wal-Mart syphon fed (which I dislike almost as much as the HF one--go figure). The vacuum feature was definitely nice, though. BTW, my compressor is a 7.5HP, 80gal., 24.4cfm Ingersoll-Rand, so it wasn't a problem with having a wimpy compressor. Maybe the Snap-On blaster would do better; I'm a poor boy so I'll never know.
  #14 (permalink)
Old 11-08-2007, 12:06 AM
BerkelUSA's Avatar
Convert that $20 Wal-Mart syphon fed thing to this:
My site & DIY Groups:PABLASTER - Rob's Projects - Powder-Coating - Metal-Casting - Lathe Group - 1930's Chevys - Fiberglas' - CNC Tables - GOT LINKS??
Power Brake Vacuum Booster poweder coating temperature jaysouth2000 Powder Coating Questions 5 01-05-2007 09:08 AM
bead blasting - vacuum to keep dust down mtnbiker Powder Coating Questions 9 03-09-2006 07:57 PM
Sand blaster leaking hefrod Metal Polishing Questions 3 12-06-2005 06:14 PM
Vacuum Metallization??? drfjr1976 Powder Coating Questions 14 11-13-2004 11:57 PM
sand blaster / bead blaster? Chevalier Anodizing Questions 2 02-07-2004 02:15 PM
