+ Reply to Thread
Results 1 to 2 of 2
Thread: Any fiishes more durable than the cold black oxide for bolts?
  1. Any fiishes more durable than the cold black oxide for bolts?
    I have a bunch of bolts to do all steel. I don't care about color but want a duarble finish. I've heard the black oxide (cold process) rubs off. Any other suggestions?
    Share with Facebook
  2. Re: Any fiishes more durable than the cold black oxide for bolts?
    Won't rub off if done right. It's a chemical process and the sealer penetrates the metal. "Parkerized" hot process Black Oxide have lasted for generations.
    The cold caswell is easier and safer but the base allows have different "openings" and pores for this treatment. See my post on BO ...
    If heat and lubridity are required consider Boron Nitride or TiN depending on cost. The Black Oxide is Great as it adds less than a Micron to dimensional thisknesses for close tolerances. Where plating and spray on coating can effect threads and seating clearances.
    Ed
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Plating preparation black Caterpillar bolts
    By borgen in forum Electroplating Questions
    Last Post: 02-27-2006, 07:30 AM
  2. Powdercoating black alloy bolts
    By sgunn911 in forum Powder Coating Questions
    Last Post: 06-20-2004, 09:15 PM
  3. Black Oxide concentrate, how durable on carb throttle plates
    By KenL in forum Electroplating Questions
    Last Post: 10-09-2003, 07:42 PM
  4. black oxide
    By bonesmachine in forum Other Metal Finishing Questions
    Last Post: 06-02-2003, 12:03 PM
  5. black oxide
    By sswhite in forum Electroplating Questions
    Last Post: 04-06-2003, 02:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
