Old 10-30-2007, 02:44 AM
dhjnyc is on a distinguished road
Default Iron, Steel, and Nickel Blackener - problem
Hi,
I used an Iron, Steel, and Nickel Blackener on black iron (an area that had been ground down). The metal was rust free and silver in color before I started. It did turn black but as it dried it also rusted in what was a matter of minutes. I am confused. The instructions were not very good maybe I did something wrong. The brand is Jax.
Any ideas as to why this happen and how to prevent it when I redo it?
Also what is the best way to clean the rust off?
thanks dj
Old 10-30-2007, 11:05 AM
erckgillis is on a distinguished road
Default Re: Iron, Steel, and Nickel Blackener - problem
Stiff SS wire brush or Soft Brass brush. The Red Oxide (rust) is the impurities leeching from the metal pores. BO is a chemical "oxidation" like rust.
It must be clean...and rust free...
See my BO post.
E
Old 11-01-2007, 02:49 AM
Hi E,
Are you saying that, even though it was ground down to the silver finish it still needs additional brushing with a steel brush? ( I will say a few days passed between the grinding down and the black oxide process). But the metal looked shiney silver and rusted immediately when I put the BO on.
The surface appeared rust free before I put the BO on it. If I don't see the rust how do I know when I have removed the rust?
I am very new at this - thanks
dj
Old 01-01-2008, 09:17 AM
tagged is on a distinguished road
When you was the acid off of your piece you should use a weak bleach solution to nutralize the oxidation. I'm not a real expert on this but I have been doing a lot of blackening lately and this has helped my flash rust problems.
Feedback: Stainless Steel Blackener 370 bgolfing Other Metal Finishing Questions 1 10-29-2007 04:23 PM
Stainless Steel Blackener 370 - who has used it? any pictures? soccergk Other Metal Finishing Questions 5 10-02-2007 01:26 PM
Stainless Steel Blackener 370 - who has used it? any pictures? soccergk Other Metal Finishing Questions 4 03-27-2007 12:06 AM
Plating steel and cast iron: Rust removal/pickle tokay Electroplating Questions 0 12-20-2006 07:40 PM
How to plate Nickel over old Nickel when steel shows through ASHENASH Electroplating Questions 3 04-22-2005 03:03 AM
Powered by vBulletin® Version 3.7.0
