+ Reply to Thread
Results 1 to 6 of 6
Thread: Cerakote Chromex VS Techline Cermakrome??
  1. #1
    Question Cerakote Chromex VS Techline Cermakrome??
    I beleive that Caswell no longer sells the Cermakrome from Techline now they only sell Cerakote Chromex. How similar are these two products? I am concerned that Cerakote Chromex is not as good. Thanks for any input.
    Thanks
    Share with Facebook
  2. #2
    Default Re: Cerakote Chromex VS Techline Cermakrome??
    No one has used both of these products? My guess is that they are probably just about the same but I would like to know for sure? Thanks
    Share with Facebook
  3. #3
    Join Date
    Apr 2004
    Posts
    475
    they are both practically the same and polish the same by hand
    chromex is more user friendly and error forgiving
    cermakrome you have to be more carefull appling it
    how ever if you are polishing in a tumbler techlines hold better.
    Share with Facebook
  4. #4
    jtag, thank you for your reply. "More user friendly"...sounds great to me! I am going to be ceramic coating for the first time hopefully this weekend. I Bought a small hvlp detail gun, a spot sand blaster, and I should be getting my Chromex tommorow from Caswell! I'm excited about trying it out.
    Thanks again.
    Share with Facebook
  5. #5
    Join Date
    Apr 2004
    Posts
    475
    it will look solid at the bottom and water at the top , that's normal
    mixing it up takes some time , you have to mix it well till they become one part
    some tips
    part must be completely cleaned or it will crack in uncleaned areas
    don't over build or it will crack
    if you get runs clean the part and start again or if possible clean the run only, if you don't it will crack .
    i use the gun at 50psi some prefer lower , but as some say "what works for you , is the best way to do it"
    Share with Facebook
  6. #6
    Thanks very much for the tips.
    I have experience painting cars but I am not sure exactly what Chromex is going to spray on like... When you paint a car you are trying to get a uniform full coverage without any dry or overspray areas. I was under the impression that with chromex you are just looking to get coverage only and that overspray or dry areas were not really a concern because you will be polishing anyway Is that correct or am I supposed to lay it on like paint??
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Unused Cerakote Chromex
    By m67bd70x in forum Used Items For Sale
    Last Post: 07-25-2006, 08:03 PM
  2. Chromex Help
    By m67bd70x in forum Powder Coating Questions
    Last Post: 12-31-2005, 03:02 PM
  3. Techline Coating Question
    By Noob2PC in forum Powder Coating Questions
    Last Post: 01-19-2005, 02:58 PM
  4. cermakrome
    By brcxsive in forum Other Metal Finishing Questions
    Last Post: 07-15-2004, 10:50 PM
  5. Techline Coatings?
    By WAORacing in forum Other Metal Finishing Questions
    Last Post: 04-21-2004, 07:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
