Old 05-05-2003, 01:07 AM
kiwigips
Default Aluminum damage
Is there a way to repair deep scratches and gouges in aluminum or stainless and then be able to polish the piece without being able to see a difference? sanding till the mark is gone is out of the question, as i would have nothing left to buff.
Thanks
Old 06-16-2003, 11:03 AM
sparts
heres something i ran across not sure how good it works or what the finish might look like but i hope it helps,its made by Locktite and its an aluminum epoxy or better known as aluminum putty it comes in a putty and a liquid form,if you use it let me know how it worked out. one other thing it was in a MSC Industrial supply book
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 01:16 PM
Do you have to use flash copper to plate aluminum krsimulis Electroplating Questions 1 07-27-2004 02:32 PM
Aluminum polishing help needed erikchow Metal Polishing Questions 1 02-25-2004 03:44 AM
Cleaning Oxidized Aluminum With Sand Blasting Media? freematt Other Metal Finishing Questions 2 02-23-2004 03:22 AM
HELP! White haze when degreasing polished aluminum! davidh90046 Metal Polishing Questions 2 10-15-2002 02:19 PM
