Results 1 to 2 of 2
Thread: "Ionic Plating" (IP) - How To REMOVE It??
  1. #1
    bres3000 is offline New User
    Join Date
    Apr 2008
    Posts
    5
    Default "Ionic Plating" (IP) - How To REMOVE It??
    This watch is coated with what the mfg. calls "Ionic Plating" (IP)
    #1 - I don't suppose it matters, but is this a "Real" process?
    #2 - Because the finish is uneven on the watch case and because the plating is already coming off of the buckle, I'd like to remove the plating altogether. (The spot on the buckle is not scratched or scuffed, it's just 'bald.')
    What is the best way to remove this plating, while leaving the polished stainless steel beneath undamaged?
    Thank you.
  2. #2
    craige's Avatar
    craige is offline Caswell Inc Staff
    Join Date
    Nov 2007
    Location
    Lyons NY USA
    Posts
    41
    Default Re: "Ionic Plating" (IP) - How To REMOVE It??
    Ionic plating is a fancy term for electroplating process, that invloves the transfer of the metal from the anode to the cathode (part being plated). If this is a decorative finish like gold or silver you can normally buff it off.
Thread Information
Users Browsing this Thread
  1. Gold Plating "magnetic" SS -Not working
    By gnathanson in forum Electroplating Questions
    Last Post: 10-08-2007, 09:18 AM
  2. Caswell's "Tinted Brass" and "Candy Gold "
    By autoshopowner in forum Powder Coating Questions
    Last Post: 05-18-2007, 07:45 AM
  3. The "New" zinc plating system
    By seanc in forum Electroplating Questions
    Last Post: 10-20-2006, 12:06 PM
  4. "Dirty" Anodes affecting plating
    By waylonh in forum Electroplating Questions
    Last Post: 07-17-2005, 10:47 PM
  5. "Hard" Anodizing vs. "normal"; differenc
    By dagobert in forum Anodizing Questions
    Last Post: 02-26-2004, 11:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
