Old 10-03-2008, 12:47 PM
glennz is on a distinguished road
Default What vibratory tumbler media?
I have the medium sized vibratory tumbler. I purchased some medium and fine ceramic triangles and some treated corn cob media with the tumbler. I am trying to strip and clean used carburetor parts (small parts not easily bead blasted like springs and other small irregular shaped steel parts). Cleaning is necessary prior to degreasing and replating in the copycad system, then yellow chromate dip final process.
The triangular media is too large to clean springs and small irregular parts. So I tried the treated corn cob. It does a semi decent job, but leaves black residue on many parts, even after days of constant cleaning. It too is not completely cleaning my small irregular parts.
Can glass beads be used in these tumblers? Would they clean the steel parts? Any other media work better than the triangles or corn cob?
Wlanut shells?
Need some help here. We had a large vibratory tumbler at work but it was more of a drum shape, it used either beads or aluminum silicate?? grit tumbling with the parts. It removed rust, old plating etc from steel parts. Used as a dry process.
Old 10-09-2008, 10:01 AM
Zinc Plating Guru
Default Re: What vibratory tumbler media?
Glenn:
You sent me a private email, and I tried to reply, but you're not accepting either direct email or forum replies.
Since you're new to this forum, maybe it's just your preference settings. Make sure you have replies enabled, otherwise we won't be able to reply.
Sean
Seans Zinc Plating page
homemade vibratory tumbler gudgean Powder Coating Questions 2 04-30-2007 10:02 PM
Vibratory Tumbler and its media (help) Gunjji Metal Polishing Questions 0 02-16-2006 06:21 AM
Vibratory Tumbler size???? GramSlam Metal Polishing Questions 0 09-02-2004 01:18 AM
Vibratory Tumbler Media hondaman100 Other Metal Finishing Questions 6 08-27-2003 08:38 PM
Media to mirror polish Aluminum in vibratory tumbler hrothgar Metal Polishing Questions 1 07-26-2003 12:32 PM
