| Other Metal Finishing Questions Discussion board for any metal finishing questions not covered in the topics above. |
I'm having some difficulty getting a clean finish with the Silvachrome. About what PSI should I be using? Does anyone else have the problem of overflow streaking the surface of the item your attempting cover with Silvachrome? When they say 70 degree temperature helps, does this refer to the air temperature of the air from the compressor or the temperature of the surface your spraying?
It seems the only way to get good results is to stop any droplets (overflow) from forming on the sprayed surface. Any suggestions? Thank You. |
| Silvachrome question | Wildkarrde | Electroplating Questions | 6 | 06-11-2004 11:16 AM |
| Looking for others who have used Silvachrome | non-stick | Other Metal Finishing Questions | 4 | 12-06-2003 10:19 PM |
| Silvachrome Topcoat Question | Therber | Other Metal Finishing Questions | 0 | 07-07-2003 03:48 AM |
| Silvachrome Question | Hughesy | Electroplating Questions | 1 | 09-03-2002 02:14 PM |
| Silvachrome question | Owen | Electroplating Questions | 10 | 06-20-2002 09:19 AM |
