Originally Posted by
bredlich
I cant for the life of me figure out how to wire this. I have 2 Clion Solid State Relay's at 40amps each running 6 burners at 2500 watts each. I was told to wire the oven like this. run one side of the burner to 1 110 leg, and run the second side of the burner to the SSR. Yes, this would be correct Once the PID kicks the SSR on the burnner would heat up. Does this sound correct? Yes, when the ssr completes the circuit by supplying the second leg of the 240 volt circuit, the element would energize. the Also, does power go to #1 on the ssr and power out to the burner go to #2? and are 3 & 4 for the PID controller? any help would be great!
