Results 1 to 8 of 8
Thread: Spray Booth for Powder
  1. #1
    eclipsespeed is offline Newbie
    Join Date
    Jul 2004
    Posts
    10
    Smile Spray Booth for Powder
    Hey guys im working on a bigger oven at the moment but at the same time i want to build a spray booth with the vacuum filter back like the ones they use here...
    deluxe base oven and powder boot
    I plan to make a booth about the same size as the new oven which will be 6X4X3. So what i would like to know is about how many CFM i will need to have adequate dust filtration without being so much that it just pulls the powder off my parts.
    That size booth is 72sf so i was thinking that around 150cfm would probably work. If anyone has any input on this i would appreciate it. Blower motors can get kinda pricey so id like to get it right the first time.
    Thanks,
    Keith
  2. #2
    Grumple is offline Experienced Metal Finisher
    Join Date
    May 2008
    Posts
    314
    Default Re: Spray Booth for Powder
    Here is some info:
    Powder Spray Booth for Dummies?...Need some help
    But at Eastwoods forum there is more. Too bad its down now for maintenance. I built mine out of wood and those shiny shower panels for ease of cleanup. I used an air handler from an old heat/ac unit that someone threw out and changed the motor from 220v to 120v. It has 6 filters and works fine.
    Building a spray booth
    Grumple
  3. #3
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Quote Originally Posted by eclipsespeed View Post
    Thanks,
    Keith
    See my Booth pics on the Photobucket link in my signature. Mine is pretty close to your dimensions, but a little bigger. Made as Grumple's,... with 2x's and a bunch of what's called "Tile board" from H-Depot. Basically it's a painted piece of thin masonite. Works really well and I used two cheapy fans from wally world to draw air with.... minimal but very effective.
    EMAIL scott@scottrodspc.com
  4. #4
    Harleydad's Avatar
    Harleydad is offline Metal Finishing Guru
    Join Date
    Dec 2006
    Posts
    833
    150 cfm won't cut it. The industry standard is 100 cfm per sq ft of surface area. If your booth opening is 6 ft high x 4 ft wide, 6x4 = 24 x 100 = 2400 cfm.
  5. #5
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    if you're using filters like that one, which i think is a bad idea, you need to make sure you use a high-pressure blower. i.e. a radial blade and not a box fan or a squirrel cage. they move lots of air, but as soon as a restriction is introduced (filters) they lose cfm dramatically. i recommend a cyclone. we use one and it's zero maintenance since there's nothing to clog.
    here's ours: Powder and Paint Booth
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
  6. #6
    Join Date
    May 2008
    Posts
    314
    Len,
    That reminds me, you never followed up with the cyclone pics and info.
    Thanks,
    Grumple
  7. #7
    Join Date
    Jul 2004
    Posts
    10
    Quote Originally Posted by FigureLLC View Post
    Yeah actually i was reading around and found the cyclone. I found one on ebay for $87.00 so im going to get one of those. I was thinking of going with something like a 400cfm blower since they are normally using that with a shop vac and the next size up cyclone recomends a 700cfm. What do you guys think? Is that gonna be to big for that unit?
    This is the unint i was looking at...
    Cyclone Separator for Shop Vacuum - eBay (item 280295922125 end time Jul-17-09 04:01:43 PDT)
  8. #8
    FigureLLC's Avatar
    Join Date
    Nov 2005
    Posts
    945
    yeah i'll try to post some pics this week.
    that's the same guy i bought ours from. i used the big one, though. maybe like a 1200cfm blower? but i wish we had a lot more flow.
    Len
    Figure Finishing
    866-900-4949
Thread Information
Users Browsing this Thread
  1. Our new Powder Coating Spray Booth..
    By welterracer in forum Powder Coating Questions
    Last Post: 07-02-2008, 03:26 PM
  2. Spray booth for Power coating AND conventional spray painting
    By mikeman in forum Powder Coating Questions
    Last Post: 06-06-2008, 03:09 AM
  3. Powder coat spray booth plans??
    By Grumple in forum Powder Coating Questions
    Last Post: 05-12-2008, 10:36 AM
  4. Powder Spray Booth for Dummies?...Need some help
    By Mark_H in forum Powder Coating Questions
    Last Post: 12-07-2007, 06:13 AM
  5. Powder Spray Booth Fan CFM?
    By ppwcanada in forum Oven Building Forum
    Last Post: 09-26-2007, 12:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
