That's definitely a tall order for 120..... Not hap'nin.
220 might even have a time of it. Some sort of gas is the answer in my opinion. Although It can be done with 220, it will be a very use specific design and would limit the ability to do other items. If you choose 220, get the a 100 amp circuit at least... do some calculations first though, to determine the dimensions, volume of the oven desired, amount of burners you'll need to heat it to cure levels, and that will help determine the proper amp rating that you will need to have installed,... if you go electric.
If you are going to do many chassis' then it would be a very worthwhile endeavor. But if you are only going to do one or two chassis/frames, An oven specifically for that might be best left alone, and the work farmed out to a coater that has the facilities already.
LinkBack URL
About LinkBacks
