+ Reply to Thread
Results 1 to 9 of 9
Thread: TC troubleshooting
  1. #1
    Join Date
    Jan 2009
    Location
    ALabama
    Posts
    16
    Default TC troubleshooting
    I hear talk of erratic pid temp. changes. My oven has been built since January and I have not had a problem with it. All the sudden the temp would climb up to 2330 degrees, then the controller would flash on and off reading, orAL. Bought a new pid 1/16 DIN PID Temperature Controller (Relay Output) [SYL-2342] - $44.50 : auberins.com, Temperature control solutions for home and industry same thing. What can go wrong with the TC? What are the dos and donts of the TC? I need help with this one I have no oven with parts lined up to be PC.
    Share with Facebook
  2. #2
    Join Date
    Jul 2006
    Posts
    738
    Default Re: TC troubleshooting
    I would first check that the PID parameter for the thermocoupler type is set correctly. Then check the tc wiring to determine if it is damaged. Does the pid read the correct ambient temperature before starting the oven?
    I would then contact Auber as they do have technical support for their products. The orAL reading sounds like some sort of alarm output.
    Share with Facebook
  3. #3
    Join Date
    Jan 2009
    Location
    ALabama
    Posts
    16
    Quote Originally Posted by ed_denu View Post
    I have checked the parameter for the TC. It does not read the correct ambient temperature.
    Share with Facebook
  4. #4
    Join Date
    Jul 2006
    Posts
    738
    Quote Originally Posted by newchapter View Post
    If the ambient temperature reading is not correct at startup, then it sounds like the tc is bad, assuming the polarity of the tc connections are correct.
    Share with Facebook
  5. #5
    Join Date
    Jan 2009
    Location
    ALabama
    Posts
    16
    . The polarity of the tc is correct and I was thinking that the tc was bad. I was working good , the next day I powered it up and started getting "orAL" flashing on the controller. It seems like its from the wiring, not at the connections of the pid. I can move the wires to get the correct ambient temp, the elements will turn on, and work fine and when the oven heats up around 320 it starts flashing again. I did manage to go threw AT with the new pid. I bought my control box from Ted and I know its not the wiring in the box. What can go wrong with the tc from the wire to the tc probe? What could of happened to make this go bad? I have searched and never heard of anybody having this problem. I hope I can get in touch with someone today, I sure would like to see some kind of light at the end of this tunnel
    Share with Facebook
  6. #6
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    885
    I can move the wires to get the correct ambient temp, the elements will turn on, and work fine and when the oven heats up around 320 it starts flashing again. ... What can go wrong with the tc from the wire to the tc probe?
    You seemed to have answered your own question. Check the connections for tightness. If they're tight and you can move the wires to make it work, check the solderless (crimp-on) connections.
    Share with Facebook
  7. #7
    Join Date
    Jan 2009
    Location
    ALabama
    Posts
    16
    Quote Originally Posted by CarWiz View Post
    Yea I know, it just seems kind of odd that all the sudden it does this. I just want to make sure that its the tc before I order another.
    Share with Facebook
  8. #8
    Join Date
    Jul 2006
    Posts
    738
    Sounds almost certainly like a bad TC. Could be loose connections like CarWiz suggested or a short between the wires and the outer stainless sheathing. Not a common problem, but it's a simple and cheap fix to replace the tc.
    Share with Facebook
  9. #9
    Tc's anneal as they get used so they can unfortunately 'drift' as its known this throws them out by a few degrees. They can break at any time causing and open circuit which puts the control instrument to show sensor break or top limit.
    Dave
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Need help troubleshooting powder defect...
    By k2 in forum Powder Coating Questions
    Last Post: 06-24-2008, 05:26 PM
  2. Rust electrolysis troubleshooting question...
    By timbn2 in forum Other Metal Finishing Questions
    Last Post: 09-11-2007, 01:07 AM
  3. Troubleshooting Chrome
    By superglide56 in forum Electroplating Questions
    Last Post: 11-22-2006, 10:15 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
