Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions > Oven Building Forum
Connect with Facebook
Closed Thread
Old 08-01-2003, 11:52 AM
getastro's Avatar
getastro
Default Oven Building Question
Okay, I am building an oven and have a local place cutting the sheet metal for the inside and out. Question is what is the best thing to use for the frame between the inside and outside. Metal, Wood, stuffed full of insulation? Just not sure and do not want to spend alot on the frame work.
Old 08-03-2003, 03:31 PM
Use metal, and when you put in the insulation try not to pack it in the more you compress it the lower the R-factor goes.Insulation is designed to have air pockets in it.This is if you are useing fiberglass which is the cheapest I have found with high R-factors.
Old 08-03-2003, 04:52 PM
getastro's Avatar
getastro
Thanks, after looking into all the items I am going with the metal. Found a local shop with 2x4 tube, just need around 100 feet.
Dale just wanted to know where you got your relay(s) at and do you use 1 or 2 pole relays?
Closed Thread
Cooking up an oven project... dagobert Powder Coating Questions 33 06-09-2008 04:43 PM
Building oven question? Deecoat Powder Coating Questions 14 04-23-2006 05:17 PM
another oven question corybarta Powder Coating Questions 7 03-15-2005 12:07 AM
building a oven question Jay87T Oven Building Forum 3 03-01-2004 06:28 PM
Yet another Oven Building question. tomg552001 Oven Building Forum 1 08-24-2003 12:42 AM
