Hello
Im building a 30'' x 30'' x 60'' oven. I am using a stand up freezer for the inside sheet metal metal studs for the outside shell with pink house insulation surrounding the whole outside. For the outside I will either be using concrete board or sheet metal Most likely concrete board because of price.
The oven is going to be heated by propane and a 55,000 btu heater. I am going as low tec as possible.
I am looking for suggestions on some part numbers for a pid, a gas solenoid, and anything else I will need other then the basic shell of the oven I have read for the last few weeks on this and other forums and am still lost.
I looked at my heater and it only needs 3 amps for ignition and total
So correct me if im wrong but this http://www.auberins.com/index.php?ma...7111aa1592af0e
would work and I would not need another relay depending on how much juice the gas valve needed to open
Thanks to all
Josh
LinkBack URL
About LinkBacks
