Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions > Oven Building Forum
Connect with Facebook
Old 09-19-2009, 09:05 PM
fullbore1 is on a distinguished road
Default Floor insulation?
I am building my oven right now 4Wx6Tx6D and am planning on placing the elements (4) in the floor. The oven will sit on a concrete floor, is there a need for insulating under the elements in the floor? Also I was wondering if I could get away with a 3 inch wall thickness using 8lb mineral wool sheets?
I was looking at putting doors at both ends and running a hanging track through the oven to be able to get items ready to go in at one end and pull out the other, Any opinions on this set up?
Thanks in advance,
Michael P.
Michael Polizzi
Full Bore Karting
KartRaiser
Old 09-19-2009, 09:49 PM
Grumple is on a distinguished road
Default Re: Floor insulation?
Hi,
A concrete floor will act like a large heat sink and suck a lot of heat from your oven. It is recommended to have an insulated floor...
On the 3" mineral wool the more the better. I used 4" but put it in the 3 1/2" space on my build.
Don't know about the roll thru option except it will take more space to have room on both ends.
Grumple
Grumple
Old 09-19-2009, 10:08 PM
CarWiz's Avatar
Caswell Platinum Member
Concrete absorbs moisture and releases it when heated. I would at least have a sheet of steel as the floor or find a heat resistant coating/covering. If your elements heat the concrete over the boiling point of water (~212), it may start popping chips all over the place. And if you've ever cut rebar out of concrete, you'll know what I mean by popping!
Old 09-20-2009, 10:50 AM
ed_denu will become famous soon enoughed_denu will become famous soon enough
If you go over to some of the powder coat forums you will find a couple of people that have large(10x10x20) propane fired ovens that sit on concrete floors. I don't think it is that big of a problem.
Old 09-20-2009, 02:18 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
Ed is right . in fact most industrial ovens i have seen have a concrete floor
but if you are to have a concrete floor that you could use to roll in the parts why would you place your elements there
Old 09-20-2009, 10:35 PM
Baz, The frame is 1 1/2" on the bottom. I will cover it with a sheet of 22G but was wondering if I should mount the elements down in the frame work or insulate it and mount above. Because I am considering using the overhead track for moving parts, I was not thinking of using a flat floor and rolling racks. I have seen what happens to rolling racks over the years. This is more for doing my product line at KartRaiser.com than anything else, but extra income is always nice. I will also build a removable divider to cut the length in half. I know it makes the fan setup a pain but it should work OK.
Another thought is what is the best way to avoid Infrared heat transfer? will an 1/8" sheet of aluminum 1" over the element the job or do I need more spacing?
Thanks all.
Michael Polizzi
Full Bore Karting
KartRaiser
Old 09-21-2009, 02:31 AM
CarWiz's Avatar
"Avoid back stress and possible lost time from work.
Take the dreaded part of the race day away!
Stop lifting those karts by hand!"
Great idea but the kart I used to race was about 1" off the ground. How do you get the kart on the lift but to lift it in place?
  #8 (permalink)
Old 09-21-2009, 01:17 PM
baz baz is offline
Thanks all.
sorry i got it wrong . since you have a bottom frame anyway and if you have the spare room then i would insulate it .
the way my oven is built , elements are mounted on the back wall then i have a 16 gage sheetmetal 4 inches in front of the elements and of course you need ventilation to circulate the air in and out from behind that shield
works just like a convection oven .
that way all of my parts are cured from the hot air and not directly from the element itself
  #9 (permalink)
Old 09-21-2009, 08:38 PM
It picks it up on the rear bumper. I designed, and have been building them for going on 4 years now. KartRaiser video link
Michael Polizzi
Full Bore Karting
KartRaiser
  #10 (permalink)
Old 09-21-2009, 09:04 PM
recklessnova is on a distinguished road
Thats cool
Where to find garage floor stud kits? norurb Other Metal Finishing Questions 2 05-13-2009 10:37 PM
New oven build, floor or no floor? Grumple Oven Building Forum 14 04-13-2009 03:11 PM
opinions on oven floor muskie Oven Building Forum 11 05-31-2008 09:47 PM
What and where can I buy a paint for the garage floor? krisnet55 Powder Coating Questions 1 01-31-2008 09:14 AM
What do you mount a standing floor buffer to? y2kgtp Metal Polishing Questions 17 08-01-2007 04:41 PM
