The parts you reference, besides the elements to some extent, are not voltage specific. PIDs(Controllers) can operate on a wide range of voltages and will work fine on 120 volts. The TC gives a reference voltage back to the pid and doesn't in itself require voltage.
Elements are normally rated at a specific wattage based on input voltage. You can operate 240 volt elements on 120 volts, but the output will be reduced to 25% of the listed wattage. There are 120 volt elements available from sources such as McMaster Carr, but they sometimes tend to be a little pricey. Another source would be to salvage an element from an old toaster oven.
If you have access to any elements their wattage can be computed if you do an Ohms(resistance) check on them with a mm. The formula is:
Wattage = (Voltage˛ ÷ Resistance)
1500 watts will be about the maximum you can run on a 15 amp 120 volt circuit. Slightly more if your circuit is 20 amp.
LinkBack URL
About LinkBacks
