I've got a chance to buy, dirt cheap, 2 ovens that were used as varnishing ovens. They are supposed to heat to 600 degrees. The question I have is about the electrical system. They are 3 phase and wired for 460 volts, I have 208 3 phase in my shop and can reconnect them to run at the lower voltage. What I don't know for sure is how much the lower voltage will affect the output of the elements. Would wiring the elements in series vs. in paralell have something to do with it? Any electrical guru's here that can help with that?
Thanks in advance.
LinkBack URL
About LinkBacks
