The hi temp fan I use is a Dayton that mounts outside the oven. It's this one:
Blower,216 CFM,115 V - Small Centrifugal Blowers - Blowers - HVACR : Grainger Industrial Supply
A radiant heat shield is best if it isn't significant enough so that it becomes a source of radiant heat itself when it reaches temperature. I used heavy duty aluminum foil with the edges wrapped over a heavy wire frame. The foil allows for convection heat but blocks the radiant effect. I did some temperature measurements with and without it in place on parts mounted in the lower area of the oven. There's no doubt it works. There are probably many ways of accomplishing the same thing, just don't totally enclose the elements with anything to thick and heavy .
