Ed,
Appreciate your response. The calculators are helpful. My main problem is that I need the elements not to glow hot at start up. Do you know if the top burner control knobs from a range would be able to be wired in to control the voltage to the range elements. In theory this would limit the voltage and not let them heat up to full power at start up. I only need to reach about 180 degrees and even 30 minutes to reach that would be OK. Thanks, Mike |
Hello,
I'm new here myself and I'm building a powder coat oven. I was wondering what you are coating that only requires 180 deg. F. I'm thinking that the proper thermostat setting in an oven would cause your power to cycle and limit temperature to 180 deg. F. Of course that will be on the low end of what an oven is capable of doing. Possibly you could use infrared lamps to get that amount of heat for only a half hour. Maybe someone else can comment............... |
If the concern is radiant heat from the elements, you could build a shield of sorts around them. But your concern is legitimate in that with a pid, the elements would be on full power until the set temperature is reached. A better pid with ramp/soak capability might help some. Last edited by ed_denu; 10-12-2009 at 08:58 PM. |
| Wanting to do golf clubs - some basic questions | tcpip95 | Electroplating Questions | 2 | 01-18-2009 02:09 PM |
| Basic Anodizing questions | OutlawPaintball | Anodizing Questions | 15 | 03-20-2007 10:46 PM |
| The most basic of 'clear' questions | terrykrueger | Powder Coating Questions | 4 | 04-07-2006 12:36 AM |
| Fumes and basic newbie questions | PeterBusch | Anodizing Questions | 7 | 10-05-2003 10:30 PM |
| Basic anodize questions | erogers | Anodizing Questions | 0 | 03-12-2003 08:54 PM |
