Originally Posted by GAWnCA
Where can I find Dave's explaination? I like that configuration set up.
It will all become much clearer once your oven is done. That is one of the last things you will do is set alarms and it can be done at any time. Just make sure you build the oven with plenty of insulation and design the fan and ducting into it. I just used a large diameter piece of the rigid EMT and made adapters to connect it to the blower and an outlet box. Worked great. As you are getting the oven build ask questions and post pics and we will help along the way...
G
