The only issue I see is needing to add a circulating fan to even out the temp.
How are you going to control the temperature? Are you going to use a pic/ssr or contactors?
Just asking because the burners usually don't have a temperature control built in - just a low, med and high setting. If you are going to use the pid,etc. are you going to save any money other than buying new burners? Are you building this on top of an oven or just a stove top. Either way you may have to somehow insulate the bottom or you'll loose some heat. Sounds interesting please be sure and post pictures if you move ahead with this project. Matt |
Actually, I was thinking of just giving it a try, and put the oven box directly on top of the stovetop. Then experiment with an empty oven, as the burners have 10 settings each (4 elements ), and install a temp sensor, possibly a fan, and just see how well, I could control it. If it works, ok, if not, I have not lost much as I would then have an insulated box to start over with. I weld, and have some metal for a frame, so sheet metal, and insulation is all I need at this point. If I do it, I will post pics, thanks for all thoughts!!
| First time Polisher question | gmann | Metal Polishing Questions | 2 | 09-16-2009 05:38 PM |
| Oven heating time | TCPC | Oven Building Forum | 7 | 03-25-2009 10:17 PM |
| ran oven for first time and now the ???? | payrion | Oven Building Forum | 5 | 03-15-2009 12:12 PM |
| Turned the oven on for 1st time - Fireworks! | BottleFed70 | Oven Building Forum | 18 | 07-17-2007 09:25 PM |
| Oven ramp-up time, how does it effect cure? | sdold | Powder Coating Questions | 2 | 11-23-2005 05:32 PM |
